some problems with CNI2
tumb1er
Message par tumb1er » Dim 17 Mai 2020 18:54
Hello, i am from Belarus, sorry for my english))
i have laguna 2 ph1 and i have installed cni2, connect all sensors: safety belt, radio switch under the steering wheel, exterior sensor temperature, exit temperature to climate control. all working, but i have some problems:
first problem is that the radio does not correctly interpret the temperature outside the window. radio tape recorder incorrectly interprets the temperature outside the window and displays with a difference of ~ 17 degrees, that is, if it is +15 overboard, the display displays -2.
second problem: I want to get access to the system settings but asks for a four-digit code. "Please enter acces code to select a system function". where can i find it?
the third problem, although this is not even a problem, but my misunderstanding. I have a renault CAN CLIP, but I don’t understand whether the multimedia system should be displayed in the multiplex tree of the car and can I access the configuration of CNI2 settings through the Clip if I connect the CAN-H and CAN-L lines to the radio.
I read MR manuals but couldn’t find anything sensible there on these issues.
thanks in advance.
Re: some problems with CNI2
Message par buron44 » Dim 17 Mai 2020 23:28
Good evening,
the access code to the configuration menu is 4112
tumb1er
Message par tumb1er » Mer 27 Mai 2020 14:54
Good evening,
thanx
