• Publicité
Cherche schémas des branchements au dos du CNI2
Re: Cherche schémas des branchements au dos du CNI2
Messagepar j2c » Mar 20 Aoû 2013 10:25
OK, it's same as I have.
Your pin out is OK on CNI2..
Do you need some info about deported display.
FYI, There is no SSPP support on CNI2 (pressure control), nor doors open info. If you haven't a matrix on the main board.. you will lose this info.
Laguna II phase 1 Dynamique 1.8L 16v
http://j2c.org
Messagepar alienpl » Mer 21 Aoû 2013 22:02
Okay, so I tried to connect the weekend
alienpl
Messagepar alienpl » Lun 26 Aoû 2013 11:07
I connected everything as it should be and not working .. :(((
pin 4 (navi) - temperature --- (1 D) gray connector pin 1
pin 5 (navi) - gray temperature OUT connector pin 2
pin 7 (navi)-Joy A1 - red 14
pin 8 (navi) - joy B1 - Red 9
pin 9 (navi) - joy A2 - Red 13
pin 16 (navi) - temp + (1 E) - 10 pin gray connector
pin 18 (navi) - straps - green connector pin 7
pin 19 (navi) - joy B3 - Red 12
pin 20 (navi)-joy A3 - Red 10
pin 21 (navi) - joy B2 - red 11
I do not know what is the problem
alienpl
Messagepar j2c » Lun 26 Aoû 2013 11:15
What is not working ?
When you plug ISO power (black) and the screen
And put the card on the reader, the CNI2 is starting. (press power button if not)
If no picture on screen.. your CNI2 is dead.
http://j2c.org
Messagepar alienpl » Mer 28 Aoû 2013 10:40
I put the card only, I don't press power button
alienpl
Messagepar j2c » Mer 28 Aoû 2013 11:00
and ? the result ?
after inserting card ?
after press power button (on CNI2)
You can check if CD is correctly injected,and ejected (the CNI2 can be on or off)
http://j2c.org
Messagepar alienpl » Mer 28 Aoû 2013 12:32
Record a video and made available here ok? need for a few days, because the car is in the service
alienpl
Messagepar j2c » Mer 28 Aoû 2013 13:10
OK, good luke ;)
http://j2c.org
Messagepar sabyn » Sam 28 Mai 2016 17:51
S'il vous plaît , si vous pouvez me aider avec le schéma d'installation CNI2 (2007) au lieu de CGI (2004).
Merci!
sabyn
Messagepar j2c » Lun 6 Juin 2016 10:12
je n'ai jamais pu mettre la main sur les schema CGI.
Tu vas l'installer dans quel véhicule ?
http://j2c.org
Messagepar buron44 » Mar 7 Juin 2016 16:30
j2c a écrit:je n'ai jamais pu mettre la main sur les schema CGI.
J'ai la NT qui concerne le CGI (NT6011A) mais je ne peux plus afficher de fichiers.
Ça m'indique que j'ai dépassé le quota d'envoi... :neutral:
Ou envoie-moi ton adresse mail en MP, je t'enverrais la NT complète si tu veux.
Messagepar sabyn » Mar 7 Juin 2016 20:02
Sur Laguna 2 phase 1 Expresion 1.9 dCi 2004
sabyn
Messagepar j2c » Mer 8 Juin 2016 15:19
Tu veux mettre un CNI2 à la place ?
J'en ai un qui ne me sert plus, et qui a été reprogrammé pour tourner sur une laguna 2 phase 1
http://j2c.org
Messagepar sabyn » Mer 5 Oct 2016 16:12
Vous Cd update 0218?
sabyn
Messagepar j2c » Jeu 13 Oct 2016 07:08
non, je suis resté en 0217 sur mon CNI2.. vu que cette mise à jour n'apporte rien pour la laguna (c'est uniquement pour la mégane 2 avec son écran motorisé)
http://j2c.org
Précédente
Retourner vers CNI 2 - Carminat Navigation Informé 2
  • Publicité
  • Publicité
cron
