I've some serious troubles with my CB CD in my Espace registered 11/2008 / OE number 281152602R:
I was doing a map update (copying to the internal memory).
i left the key in the cardreader, went for dinner, some time later i went back to the car and opened the door.
At this time the whole UCH switched the power of and the copy seemed like to stop.
Due to the fact, that i'm living at the area of Austria / Slovenia / Italy I'm doing regulary map changes and as result if this sometimes I'm aborting the update.
until now nothing bad happened.
But now i've got following error:
When i start the car, the radio swichtes immediatly on and runs, but the screen shows "Renault", goes black and again "Renault" in a loop until i power off the car.
The buttons on the radio are working, even bluetooth connectability is given and I'm possible to phone via handsfree.
Except the main error mentioned above following things are strange:
Eject Button for the CD isnt working so i had to disassemble the radio and remove the CD.
After i reconnected power supply inside the car i do not have to enter the code (even after one hour).
I allready tried with firmwareupate mentioned here:
viewtopic.php?f=7&t=937
without any notice or something similar.
For my opinion it seems like one of the chips at the headunit stopped working or is hanging - or am i totally wrong
Has anybody an idea what else can i do or some idea where to get a working flash of the headunit and do some other trials.
Even if i send it to repair i'm not sure that they can fix it because for my opinion its a serouis softwarecrash.
